Panasonic DMR-e55 keeps switching off, help?
M
Mr fuse
Hi had my Panasonic DMR-e55 for about 18 months and have been quite happy with it but recently its developed a problem where it just shuts down after a period of time.
It actually powers off all togeather and the only way to bring it back is too remove the power lead from the back and then plug it back in.
Strangely it seems okay when playing a dvd but if just watching normal tv through it via my projector it just shuts down after about 5 minutes, anyone any ideas?
I
illustrator
Sounds like it could be the fan thats packed up. When it gets too hot inside the recorder it switches on the fan but if it cant detect the fan is spinning it turns off.
hold your hand over the fan grille at the back of the machine & start to record something usually you'll be able to feel the fan kick in after a few mins
M
Mr fuse
yeah it does sound like it could be that any ideas where I can get a new fan and it is it easy to fit?
M
Mr fuse
well ive checked the fan and it deffinatly starts up but maybe it just cuts out for some reason !
Im a bit stuck now?
I
illustrator
Hmm.. see if theres are fault code
from standby (off) hold down 'STOP', 'TIMESLIP' & 'OPEN/CLOSE' on the front of the unit. It will start up and say 'servicemode' in the display.
on the remote press 0 1 , on the display there will be a code, usually this will say 'F00'. if it comes up with anything else post it here & we will find out what it complaining about.
Try not to press any other numbers on the remote it may reset the fault code
Turn the machine off to exit this mode.
If it did come up with F00 you could try initialising it but this will reset all the changes you may have done in the setup menu & it may need to be retuned for the TV again.
Same as before from standbybut this time press, 'REWIND/REV', 'TIMESLIP' & 'OPEN/CLOSE' on the front of the unit. It will start up and say 'TEST AV1' in the display.
turn it off the display will count up, '11:11' , '22:22' then unplug the machine
M
Mr fuse
followed your advice no fault code f00 then tryed intialising it but it made no difference still doing the same ?
I
illustrator
looks like its needs a visit to an engineer at this point, I'm out of ideas.
Trending threads
