Panasonic DMR E55 DVD Recorder Set-Up
Discussion in 'Blu-ray & DVD Players & Recorders' started by chris-evans, Oct 4, 2004.
  1. chris-evans
    chris-evans
    I was hoping someone could provide me with some guidance. I have the following equipment:
    Toshiba TV (2 scarts)
    Sky Digibox
    Sony Home Cinema System
    The Panasonic DMR E55 DVD Recorder is supposed to be set up as the last item connected to the TV, I can set this up to seemingly work ok using the following set-up:
    Sky Digibox into AV2 in Panasonic DMR E55 DVD Recorder
    Panasonic DMR E55 DVD Recorder AV1 into TV AV1
    TV AV2 into Sony Home Cinema System
    The problem I have is that when I want to record terrestrial TV on the Panasonic DMR E55 DVD Recorder I then cannot watch anything from the Sky Digibox. Obviously you have to set the Panasonic DMR E55 DVD Recorder input to terrestrial and I can therefore only get it to output terrestrial TV rather than the output of the Sky Digibox. There must be a workaround to this, can anyone help?
    I hope this post is clear!
    Many thanks for your help.
  2. Rasczak
    Rasczak
    Apr 3, 2002
    21,700
    Warwick
    +2,578
    There is a workaround - you can use the RF output of Sky whilst your E55 is recording. I assume you already have RF going into the E55 so just connect it to Sky first.
