Panasonic DMR E50 - Help
Discussion in 'Blu-ray & DVD Players & Recorders' started by lurcher, Jun 7, 2003.
  1. lurcher
    lurcher
    May 15, 2003
    4,216
    Stalybridge
    +221
    Just been setting up my Panasonic machines, E-50 and S75 player.
    Right, I noticed that when useing the dvd recorder remote it was also operating the player at the same time. So I went into the functions/setup of the E-50 and changed the remote setting to DVD 2 which I thought would allow independent control of the machines (wrong !).
    My E - 50 remote wont now work on its machine but happily still controls the S75 (not what I wanted).
    How can I reset it cos I cant get the functions screen back on ?.
    There does not appear to be a function button on the deck only the remote.
    When I press any button on the handset , remote dvd2 appears on the display.
    Any panasonic owners help please, I promise I wont mess around in future.
  2. lurcher
    lurcher
    May 15, 2003
    4,216
    Stalybridge
    +221
    Somehow kept pressing the button and got the function setup back on screen, changed back to original setting of remote dvd 1.
    Can control the E 50 again, but the S75 operates at the same time.
    Not messing anymore !
  3. Sie
    Sie
    Dec 17, 2002
    22
    4
    Liverpool, UK
    On the remote press select and 2 at the same time. This will set the remote to control just the recorder.
    HTH
    Sie
  4. Chrissywis
    Chrissywis
    Jun 8, 2003
    146
    16
    London
    I'm probably stating the obvious but don't forget to change the recorder to DVD 2 first otherwise you won't be able to get the setup screen.:)
  5. lurcher
    lurcher
    May 15, 2003
    4,216
    Stalybridge
    +221
    Sie/Chrissywis,
    Thanks for your instructions, new technology - old user. And stateing the obvious was just what I wanted thanks.
    Sorted.
  6. Paden
    Paden
    Jul 27, 2000
    572
    +19
    Is the multiregion mod for this machine a hardware hack or one via the remote control?
    Cheers, Paul
