Panasonic DMR E50 DVDR Problem
Discussion in 'Blu-ray & DVD Players & Recorders' started by drphibes, Jul 28, 2005.
  1. drphibes
    drphibes
    Oct 23, 2002
    1,141
    48
    +33
    Just popped a dvdr into my Panasonic MDR E50 and it refuses to play it ?.
    The screen goes dark and then suffers from interference of some sort but no sound or picture are visible.
    I have tested the unit with a ram disc and also commercial dvd films and they play back fine , any dieas what the problem might be?.
    The unit is not used much at all due to me having another dvd player that handles my film viewing needs .
    Drphibes
    Ps the unit not play cdr vcd dics aswell , they interference described above occurs when attempting to play the vcd
  2. DVD-RAM
    DVD-RAM
    You don't say which type of DVDR you are trying to play, i.e. DVD-R or DVD+R, etc.
    My E50 is none too keen to play some DVD+R discs, some it will, some it won't.
    My E55 is the same.
  3. drphibes
    drphibes
    Oct 23, 2002
    1,141
    48
    +33
    The dvd'd are dvd-r .
    Drphibes
