Panasonic DMR E50 Connections
Discussion in 'Blu-ray & DVD Players & Recorders' started by boblez, Dec 1, 2004.
  1. boblez
    boblez
    Dec 1, 2004
    4
    Just bought a dmr e50 dvd recorder and now getting a lot of grief from the wife as i cannot get it to work? The manual seems useless, how do i connect form my Phillips TV to my Sky Box and to DVD Recorder?
    Also, and i know it sounds stupid how do i get the dvd recorder to select the sky channel?????????????????
    Thanks in anticipation
  2. MuffKing
    MuffKing
    Easy.
    Scart the Sky TV-output to AV2 in the E50, then scart AV1 on the E50 to the TV.
    To record SKY simply select AV on the TV to monitor the DVD recorder and then select AV2 on the E50, finally hit record, job done :)
  3. boblez
    boblez
    Dec 1, 2004
    4
    Yep that worked fine, thanks for your help
    :hiya:
