Panasonic DMR-E100H Deleting Jpegs
Discussion in 'Blu-ray & DVD Players & Recorders' started by Bjay, Aug 24, 2005.
  1. Bjay
    Bjay
    Some time ago I copied Jpegs to a DVD disc, probably via computer. When I viewed them from the DVD disc on the Panasonic they viewed O.K. But somehow they copied over on to the hard drive. I can't see a way of deleting them. Anyone know how to?
  2. Rasczak
    Rasczak
    Apr 3, 2002
    21,710
    Warwick
    +2,585
    From memory (which is a little hazy after not having used thos feature for a few years) - with the HDD selected goto Functions and select JPEG. This will bring up the JPEG menu and if you scroll down one option is to delete. I seem to remember the first JPEG menu screen not visibly having a delete option - but if you scroll down there is a second page with delete as an option.
  3. Bjay
    Bjay
    Thanks Ras didn't think to scroll down. It worked fine.
