Panasonic dmr e100 or e95
Discussion in 'Blu-ray & DVD Players & Recorders' started by neil_uk, Jul 30, 2004.
  1. neil_uk
    neil_uk
    I'm really interested in getting a DVD recorder with a decent sized hard drive and quality connections to my Digital Camcorder. It looked like the best option was the e100, but then Panasonic went and released the e95 and confised me.
    As far as I can tell the only difference is the hard drive size, but why then is the bigger machine cheaper? Is there something I'm missing about the e100?
    Ta
  2. carlton
    carlton
    The E95 is a generation on than the E100 with better decoding ,prog scan
    updated menus etc. I.e the better machine.
  3. Rasczak
    Rasczak
    Apr 3, 2002
    21,700
    Warwick
    +2,578
    Agree with everything Carlton says - the Panasonic E95 is the replacement for the E100 - so get the latest unless you come across some amazing deal on the old model.
  4. get1a2get1a2
    get1a2get1a2
    My Brother Works For Panasonic And It Is A Update From The Dmr85
    The New Panasonic Out In October Will Be The Update To The Dmr100
    The Dmr May Have A Updated Harddrive But Misses Out Mpeg4 Writing To And From A Sd Card
  5. Rasczak
    Rasczak
    Apr 3, 2002
    21,700
    Warwick
    +2,578
    Which is useful if you have a Panasonic or Samsung portable media player and fairly useless otherwise. The E95 is a generation ahead of the E100 and should be the default choice...
  6. TL0
    TL0
    Mar 28, 2004
    9
    Rasczak:
    Hi, you seem to be very knowledgeable about these DVD recorders.
    Just wondering if you knew wether any of the current HD recorders are able to record from an external source (eg) VCR) direct to a blank DVD disc, so you don't have to copy it to the HD first.
  7. Rasczak
    Rasczak
    Apr 3, 2002
    21,700
    Warwick
    +2,578
    Virtually all standalones and HDD/DVDR combos will allow you to do this - the only one that doesn't is the Toshiba RDXS30 (the precursor to the current, excellent 32 model that CAN record directly to disk).
  8. neil_uk
    neil_uk
    Thanks for the info everyone.
  9. Rob20
    Rob20
    Jul 3, 2004
    3,100
    +664
    If you're looking for a dvd recorder with a large HDD, Pioneer has one with a 250GB HDD coming out in Dec, (according to What video & widescreen tv mag).
  10. steveho
    steveho
    Apr 21, 2004
    165
    +3
    the 95 has progressive scan and the 100 hasn't
    steve
  11. Rob20
    Rob20
    Jul 3, 2004
    3,100
    +664
    Personally I'd go for the 95. Progressive scan capable, (pal/ntsc), as well as twice the HDD capacity. Plus it's roughly the same price from mail order at £650 ish...
  12. BlackRaven
    BlackRaven
    Jan 12, 2004
    73
    11
    Warrington, UK
    I have been told that the E100 is a better built machine, and the E95 is aimed to be lower priced (hence the E100 still being more expensive).
    If the E100 was now out of date, why wouldn't they reduce the price of it to below the E100 to get rid of old stock.
    Does the E95 have a digital audio coax output as well by the way?
  13. get1a2get1a2
    get1a2get1a2
    but the panasonic dmr95 has not got the looks the build quality or mpeg4 conversion i still think the dmre100 as i have one .looks great compared to the newer panasonic dvd recorders also the dmr95 is not a upgrade to the dmdr100 the new one out in october is the upgrade the the dmr100 the new dmre500
  14. BlackRaven
    BlackRaven
    Jan 12, 2004
    73
    11
    Warrington, UK
    I heard that the newer version of the E100 does not convert to mpeg4 anymore.
  15. Rob20
    Rob20
    Jul 3, 2004
    3,100
    +664
    How useful is it to be able to record in mpeg4? how many people have a compatible sd card player?
  16. Rasczak
    Rasczak
    Apr 3, 2002
    21,700
    Warwick
    +2,578
    Not many ;) Useful if you want to watch your recordings on the train I suppose.
    As for build quality IMHO none of the Panasonic range since the E20 have had anything resembling 'decent' build quality!
  17. BlackRaven
    BlackRaven
    Jan 12, 2004
    73
    11
    Warrington, UK
    Any other opinions on which of the 2 I should got, or is everyone of the opinion that the E100 wins it out of the 2.
    I have an XDA, and that should be capable. As I have a 512mb SD card for it, I should fit quite a bit on there as well.
  18. OARDVD
    OARDVD
    Jul 6, 2003
    241
    16
    Deepest Hertfordshire
    Agreed :smashin: The build quality of the 20 was like a tank in comparison with modern day models - and all the better for it IMO. Oh well, we demand cheaper models with more & more features so ...
  19. GadgetObsessed
    GadgetObsessed
    Jul 6, 2001
    2,104
    116
    +907
    Another option may be a cheap Panasonic HS2 - there must be a few of these knocking around. I saw one for sale at Richer Sounds for £200.
  20. BlackRaven
    BlackRaven
    Jan 12, 2004
    73
    11
    Warrington, UK
    I was looking for something more than the Panasonic HS2.
    I am still undecided between the E95 and E100. I have my order on standyby with the shop (although I have paid for the E100) whilst I decide!!
    EDIT
    Have just confirmed to order the E100 now - hope I have made the right choice :confused:
  21. get1a2get1a2
    get1a2get1a2
    get the e100 as they are getting harder to get hold of i have had mine 2 years and it has nerver let me down plus it looks alot nicer then the newer models
  22. BlackRaven
    BlackRaven
    Jan 12, 2004
    73
    11
    Warrington, UK
  23. get1a2get1a2
    get1a2get1a2
    dont like there terns and conditions of sale
    Restocking Fees if you change your mind
    All non-defective returns may be subject to a 15% restocking fee on the value of the product. The product must be returned with all of its original packaging and accessories. There will be an additional charge for any missing items.
  24. ovenglove
    ovenglove
    I thought the distance selling act entitles you to to a Full refund if bought mail/internet order within so many days.
  25. get1a2get1a2
    get1a2get1a2
    do you like it
  26. kenfowler3966
    kenfowler3966
    Jul 23, 2001
    844
    leeds UK
    +14
    Restocking fees are illegal for mail order sales, just point out to them that they are breaking the law, and threaten to report them to trading standards. Its time this practice was stamped out, as too many peolple are throwing away money that they don't need to through ignorance.
    You are only responsible for the cost of returning the goods if this is clearly set out on the order conditions
  27. BlackRaven
    BlackRaven
    Jan 12, 2004
    73
    11
    Warrington, UK
    It only arrives Monday. I ordered it Friday, and there was a charge for a Saturday delivery, so I have arranged for it to be delivered to my work on Monday.
