Panasonic DMR E 100 1 to 2 min bug
Discussion in 'Blu-ray & DVD Players & Recorders' started by radicalrad, Jul 8, 2004.
  1. radicalrad
    radicalrad
    i have had the dmr e100 now for a few months and am on me fourth machine all with the same problem..
    if i record from and external dvd on to a dvd-r i get a wierd 1 to 2 min bug it will start recording and somewhere between these times it will stop recording and start again (its almost like its trying to cache or something and fails so stops and try's again)loosing maybe say 10 or 20 seconds between the two recordings so i end up with 2 files on the dvd when i am finished this has also happened when recording from the tv..oddly if it does it and i stop it after the 2 min mark and delete the files on the disk and start a gain it will be fine and record straight through :confused:
    does anyone else have this problem and is there a solution to it :lease:
    i am a little tired of keep sending the machine back to panasonic.
    thanks for any help.. :beer:
  2. Rasczak
    Rasczak
    Apr 3, 2002
    22,034
    Warwick
    +2,898
    It's an unusual problem - it hasn't come up on the forum at least. The most obvious cause is either some incompatibility with the DVD player your using or cheap, partly incompatible media. I assume you have varied the latter during your troubleshooting and the former their isn't much you can do about unless you have a spare DVD player lying about.
    Have you tried recording to the HDD and then dubbing to DVD-R? If it stops and starts when recording to the HDD at least then you can 'combine' it using the Playlists.
  3. OARDVD
    OARDVD
    Jul 6, 2003
    241
    16
    Deepest Hertfordshire
    I occasionally had this problem in the past on my old E20. The cause was attributed to using cheap discs. I changed to using quality branded media about two years ago and since then I've rarely had a problem of any sort (with either the E20 or the E100).
    It's comparatively rare for Panasonics to have problems (using decent media), so the fact that you're on your 4th machine means that you should probably look at other causes.
    Regards
    OARDVD
  4. anth63
    anth63
    Hi, what brand of DVD-Rs do you use for your E20, I've tried a multitude in mine with varying degrees of success.
    anth63
  5. OARDVD
    OARDVD
    Jul 6, 2003
    241
    16
    I currently use TDK 1-4X discs marked with a TYG01 code. To be honest, now that I've got the E100 I mainly use them in that machine now and usually just use RAM in the E20.
    Regards
    OARDVD
