Answered Panasonic DMR-BWT850EB put programs into groups
Pineman
When I record a 'series' of programs they are all grouped together and the list will show how many have been recorded within that group.
I have a number of grouped programs but occasionally one will be listed individually. Is it possible to drag that one back into the group it should have been in.
Gavtech
Administrator
Yes. - I can't remember how at the moment and I'll find out if necessary - but the most likely way will be to select the group and the title you wish to add ( by using yellow button as I vaguely recall?)... then go to Option / Create group.
Come back if you get nowhere.
Pineman
The Yellow button 'Selected' the errant program. Having done that I 'Copied' it with a view to moving it to link up with it's mates and was given the option to Copy it to Disc or Move it to USBHDD. Other Functions didn't help.
Pineman
I did it!
I should have 'Selected' both the errant program and the group it had escaped from. Then using the Option button I was able to Create the new group.
All are now happily back together.
Thanks for your advice, which helped me find my way to resolving the problem.
