I have recently inherited a Panasonic DMR-BWT800 Blu-ray Disc Recorder from my late mother, and it is driving me mad! It persists in requiring the child-lock PIN to be entered in order to watch any programme recorded (presumably with the "guidance" flag set) in the evening or overnight.
I have read the manual and searched online for answers, and have confirmed that the child lock is turned off on all the channels in the channel set-up menu and is turned off for all playback of both DVD/Blu-ray discs and for the HDD. As far as I can determine from the settings, it should never ask for a PIN.
However it still does, but only for HDD playback of programmes recorded after the watershed. It allows me to watch these programmes and to watch DVDs etc without needing the PIN.
I have tried a full "initialise" to both "shipping condition" and "default settings", neither of which has made any difference.
I have also tried to carry out the instructions in the manual "to reset the rating level settings" which according to the manual involves the following steps:
1. Press and hold [OK] and the yellow and blue buttons on the remote until "00 RET" is displayed on the unit
2. Press the "right arrow" on the remote until "03 VL" is displayed on the unit
3. Press [OK] on the remote or [OPEN] on the unit, "INIT" is displayed on the unit
However although steps 1 and 2 work exactly as described, when I get to step 3 the "INIT" message is not displayed, the unit simply returns to the channel display, and nothing is reset.
I know that there is a huge wealth of knowledge in this forum and was hoping that someone would be able to tell me what the correct process for resetting the rating levels for this unit is (I have noticed that there is an error in the manual with the process for resetting the Owner ID settings - which does work - and rather hope that it is also just a case of there being a simple error in the instructions above).
I know the PIN number for the unit so this problem does not stop me using the unit, it is however extremely annoying constantly to be prompted for a child lock PIN in a single-occupancy household with no children, and it is even more annoying when the manufacturer-provided instructions clearly do not work!
Any help or advice would be very gratefully received.
