Panasonic Dmr 95 And Ntsc/pal
Discussion in 'Blu-ray & DVD Players & Recorders' started by BENSONDOG, Nov 9, 2004.
  1. BENSONDOG
    BENSONDOG
    :lease:
    I have a multi-region Panny DMR95 connected to a Sony TV (NTSC compativle) and when viewing R1 DVDs I have to go to functions and change the connection from PAL to NTSC. Not a problem.
    However if I am viewing the R1 disc and and am recording at the same time the recording is in NTSC format. Not a problem as my TV is compatible.
    Unfortunately I am unable to view the recording even if I switch the connection to NTSC (the same as with a DVD) The recorded programme appears to be in the NTSC format. (It has the "N" tag in the thumbnail and the picture looks like NTSC format, (A black line across the top and out of focus) but will not play.
    I`m sure that the Panny has been chipped ok as all my R1 DVDS play without problems
    Does anyone have any ideas as how I can resolve this. ??
    Thanks muchly
  2. josaka
    josaka
    Nov 7, 2004
    33
    hi
    that is one of the questions in this thread...
    japanese model dvd/hdd for uk tv recording/playback?
    its thought that you have to check if the machine actually plays AND
    records the format you want...
  3. BENSONDOG
    BENSONDOG
    I don`t think that is the issue as the Panny is a UK model. The TV and the Panny are compatible, but if I`m viewing a R1 DVD it and record at the same time it will automatically record in NTSC.
  4. Siamese Cat
    Siamese Cat
    May 31, 2004
    619
    46
    London
    +137
    I've got the e85 - also multi region - and have noticed the same thing. I was watching a r3 dvd -ntsc- whilst trying to record a programme off Sky. Couldn't play it and assumed that that was because the machine tried to record a pal signal in ntsc. Complete dog's dinner I should think. NTSC 50 anyone?
