Question Panasonic DMP-UB900 Multi-Region
Discussion in 'Blu-ray & DVD Players & Recorders' started by ++ Jase ++, May 16, 2018.
  1. ++ Jase ++
    ++ Jase ++
    Aug 10, 2009
    225
    +26
    Sorry if this has been asked a million times before I searched but only found really old threads.
    I have Panasonic DMP-UB900 4K Player. At the moment I only have UK 4K movies but I have a lot of standard Blurays/DVD's from the US.
    What are my options for making this Multi-Region? Ideally I'd like everything Multi-Region but if not being able to play be old stuff would be handy.
    Something simple would be great. I remember buying a gadget for my old player that had an infrared transmitter on it which you used once to update the firmware or whatever it did.
  2. simonlewis
    simonlewis
    Jul 31, 2014
    4,199
    stockport
    +1,549
    None at all it's just not possible.
  3. doug56hl
    doug56hl
    Feb 27, 2006
    4,328
    +2,563
    You can easily make multi region for DVD by using a remote hack. Sold on ebay for around £14
    Panasonic DVD / Blu-ray player multi-region hack remote | eBay
    This lists as compatible with the UB900.
    Or read
    Panasonic DVD players region free hack now available
    and
    Panasonic DVD players region free hack - Part 2
    You can also use for DVD, if I remember correctly, All for One remotes programmed with the code sequence. Or Harmony remotes Harmony Remote Multiregion DVD Hack for Panasonic, Pioneer & Sony Blu-ray's Part 3
    Blu-ray multi region is only possible using hacked firmware.
    See above
  4. ++ Jase ++
    ++ Jase ++
    Aug 10, 2009
    225
    +26
    Thank you, that looks like the gadget I used many years ago. At least I'll be able to watch my DVDs which are mostly US versions.
