Panasonic DMP-BD60 Trouble Soldering
k2laser
I just received the Rattlebyte VFD mod. I did not know that it was going to be so difficult to solder. I haven't attempted yet, for the spots to solder are microscopically tiny. I do not know where to find a professional to do it for me. Any suggestions? Maybe a special glue can be used for the connections?
paulr2006
Try & find a local independent TV/Electronic repair shop it should be quite inexpensive to do by a professional but expensive to put right if you don't feel confident or have a reasonably fine soldering iron. Glue is not an option :)
Ekko Star
10 watt solder iron, very fine tip, professional person.
If you're not up to it, do not try it and risk destroying your player.
