Panasonic DMC-FZ20.Advice please !
Discussion in 'Photography Forums' started by av L, Jun 11, 2005.
  1. av L
    av L
    Dec 12, 2004
    24
    surrey
    I'm considering purchasing a Panasonic Z20 & would like to know from an owner of one,if it is possible to fit filters to the lens of this camera ?
    If so,what size thread does it require :confused:
    Thank's.
  2. seany
    seany
    May 1, 2003
    2,997
    61
    Manchester city
  3. seany
    seany
    May 1, 2003
    2,997
    61
    Manchester city
  4. av L
    av L
    Dec 12, 2004
    24
    surrey
    Thank's all,much appreciated ! :smashin:
  5. RockySpieler
    RockySpieler
    May 23, 2005
    1,661
    Snaking the Lineup
    +115
    In the long run, if you are going to buy a few filters for the FZ20, it's far cheaper to buy a 62mm thread adapter.........I got mine from ebay, via China, the seller also had some brand new cheap Pro Hoya filters.
    http://cgi.ebay.com/Phayee-adapter-...ryZ30059QQssPageNameZWD1VQQrdZ1QQcmdZViewItem
    http://stores.ebay.com.cn/phayeedigital
    I initially discovered the option through the FZ20 forums on stevesdigicam site......well worth a visit, great photos.
    http://www.steves-digicams.com/
    Smaller adapters are available, but the 52,55 and 58mm filters may be visible when on a wide angle.
    As well as fairly standard filters (which you may already own) you can then add additional lens such as the Olympus WCON-08B, and TCON-14B, I've also got a close-up macro lens kit.
    Unfortunately I am more enthusiastic about buying kit than actually using it..........
