panasonic dirty picture(help)
Discussion in 'General TV Discussions Forum' started by leedsfireman, Mar 21, 2002.
Tags:
  1. leedsfireman
    leedsfireman
    Mar 21, 2002
    1,232
    38
    +3
    hi, i have a tx36pf10, tosh sd210e dvd, qed rgb scart. unhappy with picture from dvd. i am not getting a good clean pic, colours not crisp, no good detail. it seems that the whole pic is dirty or dusty if you can imagine. the bright backgrounds have a mottled effect and some bright colours seem to flicker. i have tried my dvd player and scart on a shop's lowe tv and the picture was a 100% better so no prob there. has any one else had the same problem, is there a fault with the tv or are the panasonic's picture not as good as i am expecting. any help would be great.
    many thanx,
    andy.
  2. andypandy
    andypandy
    Feb 6, 2002
    594
    Surrey, UK
    +10
    There are a few picture setting adjustments , as mentioned in the previous post, but if you are still unhappy - it could be the TV.
    I too own the TX36PF10 and I am perfectly happy - the set is 2 years old and I took an extended 5 year gurantee with Domestic & General as the panasonic guarantee cost more and covered less !!!.
    With TV's this big and HEAVY, it pays to extend the warranty.I have heard a story of a Panasonic TV just over a year old and out of guarantee with a blown tube !!!! Panasonic did absolutely nothing to help with the cost of repair or replacement - and arguably...why should they ? granted it should not of happened to a year old TV, but they are ultimately built by humans even if robots were used (get it !).
    I digress a bit......honestly, I hope it is not your TV.
