Panasonic digibox keeps freezing....
Discussion in 'Satellite TV, Sky TV & FreeSat' started by BOUMSONG, Oct 23, 2004.
  1. BOUMSONG
    BOUMSONG
    Oct 23, 2004
    898
    +22
    Ive been watching sky today for quite a bit and about 6 or 7 times i have had t switch the box off at the wall for a couple of minutes becuase it has completely frozen. It happened a couple of months ago but then suddenly stopped. Its started again though. Ive told lots of people about this - some people have said to try and shorten the lnb cable etc. People have also told me to reset the box and i did this but about an hour later it went dead.
    I'll probably have to get in a sky engineer. I know they charge 64 quid to come out BUT ive been told if you threaten to cancel they will sort the prob for free
    PS- i have had sky for about three years... :suicide:
  2. BOUMSONG
    BOUMSONG
    Oct 23, 2004
    898
    +22
    Nobody?
  3. PjPip
    PjPip
    Jun 16, 2004
    326
    +9
    Had a similar problem a while back - ended up (after 3 boxes) needing a dish/LNB re-alignment. It was around the time the cards were changed so I made a lot of fuss about that when making phone calls.
    I did start off though by phoning up to cancel ;) Never paid for a call-out or replacement part once :smashin: Guess if they'd called my bluff I would either have looked a bit silly or ended up without Sky. Having just cancelled today it would probably have been the latter.
