Panasonic digi box-Change rf output?
Discussion in 'Satellite TV, Sky TV & FreeSat' started by johnsg, May 15, 2005.
  1. johnsg
    johnsg
    I have the Panasonic digi box TU-DSB31 and have a feed to a second tv that has a vcr and dvd recorder setup. When I turn on the dvd recorder I often get a little interference of a vertical line moving left to right. Could this be caused by a clash of frequencies and am wondering if an rf output change from the digi box would help. If so how can I do this. Thanks.
  2. rich1231
    rich1231
    Sep 3, 2004
    122
    sounds like interference, the RF output can be a pain. Your never likely to get a great picture. Try disconnecting the Aerial from connection for terrestrial TV. If you are using sky for all your viewing it wont matter and the interference will vanish.
  3. GGTVBD
    GGTVBD
    Feb 5, 2004
    3,396
    Bradford, West Yorkshire.
    +324
    Been answered many, many times before.....
    Services - 4 - 01select in that sequence.
    Good luck. Welcome to the forums BTW. :)
    A. Dork
  4. johnsg
    johnsg
    Rich & Arthur, Many thanks to you both.
