Panasonic CRT range updates
Discussion in 'General TV Discussions Forum' started by No-One, Nov 6, 2004.
Tags:
  1. No-One
    No-One
    Nov 6, 2004
    194
    28
    Rutland
    +29
    I've been thinking about getting the TX28DTX10 for a while. I just checked the Panasonic web site and I see it's now listed as the TX28DTX10C. I've looked through the list of specs with those for the TX28DTX10 on the multiregion magic web site (who I will be buying from) and can't see anything different at all. The pictures of the set and stand all look the same too. Has anyone got any idea what if anything has changed?
  2. red16v
    red16v
    Aug 20, 2004
    552
    +5
    Usually the 'C' on the end of Panasonic tv set means 'comes with a stand'. I remember researching the TX32PD30 and sometimes saw it as a TX32PD30C - the 'C' just meant it came with a stand (in fact it was nigh on impossible to buy it without a stand !) Hope this may clarify things a bit ? regards, yt
  3. No-One
    No-One
    Nov 6, 2004
    194
    28
    Rutland
    +29
    Ah, that should be ok then. Thanks
