Panasonic connection problems
Discussion in 'Blu-ray & DVD Players & Recorders' started by Angus, Sep 5, 2004.
  1. Angus
    Angus
    Hi All, I have just bought an (ex demo) panasonic dmr-e50 and am having some connection problems.
    I have a fairly old Bush tv (2571NTX) with only one scart and am also trying to connect it with a Sony freeview box (VTX-D8000).
    At the moment I have scarts between the freeview and dvdr, and a scart from each into a multiple scart adaptor going into the tv. I have the aerial going into the freeview box, then the dvdr and finally the tv.
    Unfortunately can't get a picture if freeview is turned on- otherwise it is ok.
    I'm a bit of a technophobe- any help, suggestions much appreciated.
    Angus
  2. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    if freeview wont pass signal in stanby that is very odd. Also for recording connect FV to Input on DVDR for better quality recirding.
  3. Rasczak
    Rasczak
    Apr 3, 2002
    21,775
    Warwick
    +2,676
    Just to expand upon what Hornydragon has said, I suggest you change your setup slightly. Ensure you use the TV Out Scart of the Sony to connect to AV2 on the Panasonic E60. Then hook AV1 on the E60 to the TV Scart. Ensure the Sony is set to 'RGB' Menu/Settings/Picture (from memory) and ditto for AV1 and AV2 on the E60 (Functions/Setup/Connection).
  4. Angus
    Angus
    Thanks for your help guys, I'll see if that sorts it out.
