Panasonic confusion!!??
Discussion in 'Panasonic TVs Forum' started by nicksurrey72, Mar 9, 2005.
  1. nicksurrey72
    nicksurrey72
    I have been offered a 42 panasonic plasma... but which one is best?
    I am confused.. I am seeing TH42PW7B, TH42PHD7, TH42PWD7 and then there are some others TH42PE30B etc etc.... So given that this will cost me next to nothing what shall i go for?
    I currently have an old generation Fujitsu plasma with fans etc
    Denon 3803 receiver
    Denon 2900 DVD
    SKY + running through the 3803 then Component to the Plasma
    Monitor Audio 8si fronts & centre, Monitor rears
    REL Stratus sub
    Appreciate your knowledgable feedback! :)
    Nick
  2. MAW
    MAW
    Jan 24, 2002
    14,103
    Nr Dorking
    +411
    Hi, I think most would agree that for your system, the 'best' will be the PHD7, it's the pick of Pnasonic's bunch anyway, and you already have sound taken care of, and component video switching. You will need a component video board as well.
  3. wicket
    wicket
    Nov 23, 2004
    493
    Middlesbrough
    +10
    I have the Panasonic TH42PE30 and it is an excellent plasma tv. I think the other models you quoted are plasma display units only so you would need to add other components to it. The TH42PE30 is a tv with Freeview and analogue tv tuners.
    I think you are pretty safe going for any Panasonic screen, it just depends on what type of plasma you want.
  4. nicksurrey72
    nicksurrey72
    Thanks, what are the differences between PW7B, PHD7 and PWD7?
    Nick
  5. MAW
    MAW
    Jan 24, 2002
    14,103
    Nr Dorking
    +411
    Wicket, he already has all those other components, if the screen is near enough free, the HD panel only model is the one.
    Differences are colour of bezel, and the PHD model is high res, and much improved processing.
  6. Steve_P
    Steve_P
    Jul 3, 2004
    1,338
    67
    +142
    PW7B - Consumer plasma display panel for UK market, 852x480 res.
    PHD7 - Business plasma display panel, 1024x768 res.
    PWD7 - Business plasma display panel, 852x480 res, essentially the same as the PW7B bar minor enhancements.
    Listen to MAW, you know he makes sense :smashin: The Hi-Def panel is the one to go for. I have the PE30, like wicket, and whilst it is an excellent TV, it's not the best choice for you given your other AV equipment.
    S.
  7. nicksurrey72
    nicksurrey72
    Does that mean I am stuck with a Black bezel??
    Thanks for the help!
    nick
  8. hornydragon
    hornydragon
    Dec 19, 2001
    28,345
    +1,218
    What colour would you like sir???
  9. nicksurrey72
    nicksurrey72
    Well, I am not too fussed but the Mrs seems to prefer a silver one!
  10. hornydragon
    hornydragon
    Dec 19, 2001
    28,345
    +1,218
