Panasonic Component problem this can't be right...
Discussion in 'Panasonic TVs Forum' started by Paul Reading, Feb 2, 2003.
  1. Paul Reading
    Paul Reading
    Feb 2, 2003
    96
    I have the Panasonic TH-42Pw4 with the RCA terminal board. When I use the component input I can only have either 16:9 or zoom. How on earth can I watch 4:3 material without cutting off the top or bottom of the film?
    This is so frustrating as I was hoping to but the Pioneer AX-10i and only use component input for all my video sources. Obviously I could go back to using s-video but having just bought the Arcam DV88+ I want to use the componant-progressive scan output.
    Is there a workaround or a firmware upgrade for this or is it a 'Known issue'.
  2. jmack
    jmack
    on component imput you will get zoom/16.9/4.3 unless you are using progressive scan then its only zoom/16.9
    hope this helps
  3. Paul Reading
    Paul Reading
    Feb 2, 2003
    96
    Well that will solve the problem, but it is hardly satisfactory. I want to use PS obviously, do all plasmas have this problem, is there a fix that you know of, can I get the firmware upgraded?
  4. CarlB
    CarlB
    Jan 8, 2001
    1,288
    Cambridgeshire
    +219
    Not sure if all plasmas display this behaviour, but you are correct about the Panasonic. My Denon 3800 DVD player has a 'squeeze' option in the setup, which then recognises a 4:3 source and displays it correctly when the plasma is set to 16:9.
  5. steelej
    steelej
    It's only the series 4 that has this limitation, the 5 series panny allows all aspects in component/progressive.
    John.
  6. Paul Reading
    Paul Reading
    Feb 2, 2003
    96
    Oh great. Is it possible to upgrade from 4 to 5?
