Panasonic - Charcoal vs Silver Bezels
Discussion in 'Panasonic TVs Forum' started by Hawklan, Dec 13, 2004.
  1. Hawklan
    Hawklan
    Oct 20, 2001
    6,744
    Essex
    +312
    My Order is in for a Panasonic TH-42PWD7
    Before the ink has dried – I thought I’d ask a potentially lame question
    I showed the missus the screen last night in another shop – Her response to which was it’s nice but looks a bit small, and I agreed.
    When I demoed the screen there was a 42PWD6 with a charcoal bezel there as well.
    The silver model was on the wall and the charcoal on a stand but the same distance away
    Now weird thing was that the charcoal version looked appreciably bigger – Initially I thought the silver one was a 37”
    The guys in the shop explained that it was because the silver model was on the wall and the charcoal on a stand – And when switched around the Charcoal one would look smaller – But I’m not so sure
    Has anybody else had a chance to compare the two models and feel that there appears to be an perceived difference in size
    Many thanks
    RON
  2. spook
    spook
    May 18, 2004
    157
    so only the perception of size matters to your missus!! :smashin:
    anyways whoever thought silver was a good colour for anything other than spoons? yuk :D
    spook
  3. Hawklan
    Hawklan
    Oct 20, 2001
    6,744
    Essex
    +312
    I just knew when I was writing this the innuendos might run rampant
    Silver looks good but!!
  4. Gussie
    Gussie
    Oct 19, 2004
    1,237
    48
    +79
    Hawklan - I've had a silver Samsung 42S3 42" and a charcoal Panasonic PW6 42" in my lounge - both on their respective table-top stands about 12 ft away from me sitting on a 32" high entertainment unit.
    At first, before seeing the charcoal Panasonic 42" - I really wanted the charcoal finish - thinking it would be better - less distracting from the image etc etc
    NOW after I've seen both - to my eyes the 42" image on the charcoal Panasonic actually looked SMALLER than the 42" image on the silver Samsung!
    Plus the silver finish just looked more pleasing to my eye !
    Before you ask - yes I did measure the diagonal - both were 42" !!!!
    So, I switched to wanting silver instead and now have ordered a silver PWD7!
    Be warned though - you will soon get used to 42" and start thinking what all the fuss is about - oh dear - is it going to be toooo big !!!!
    Listen it's never too big :D !!!
    Gussie :)
  5. oaky7
    oaky7
    hi
    this is my first post on this site and i am thinking of buying a panny th50pv30 and was trying to find someone who has one to give me their opinion. also i wanted to know when it says (svga xga compressed ) means the th50pv30 is vga but does any one know to get xga.
  6. sunil1234
    sunil1234
    Dec 5, 2004
    1,328
    63
    +121
    why do people have to hijack other peoples threads? :rolleyes: :mad:
  7. sunil1234
    sunil1234
    Dec 5, 2004
    1,328
    63
    +121
    Only my opinion but the silver looks more modern than charcoal and, at the end of the day, its not how big it looks but what you do with it that counts :D
    Seriously, would the silver be a better match with your other AV gear (dont know as it wasnt mentioned)
  8. Hawklan
    Hawklan
    Oct 20, 2001
    6,744
    Essex
    +312
    I think Oaky7 just made a mistake posting so no worries
    I've got a bit of a mix and match colour wise
    Tag Av32R + Parasound 2205 (Both Black)
    Tivo
    Arcam DV27 (Silver)
    Speakers + Stands Black
    So a combo of silver and black - The Plasma with be mounted (no pun intended) on a white wall
  9. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    TH-50PV30 is a 1366x768 res unit if you are wanting to use a PC connected to it be warned the 15 pin D-sub input is on the front of the panel under a flap......
  10. Ekko Star
    Ekko Star
    Mar 18, 2002
    6,619
    London
    +468
    The bezel thing is interesting since these are commercial panels and are really made for that purpose.
    Ideally for HC use you really want a dark a bezel as possible, reason being your eyes perceive a better contrast if you have a dark contrast around the picture.
    It's the reason why consumer panels tend to have black bezels. ;)
  11. Hawklan
    Hawklan
    Oct 20, 2001
    6,744
    Essex
    +312
    Ah!
    Ekko Star now that makes sense
    Looks like I may be changing my order to one with a Black bezel
  12. Lizzard
    Lizzard
    Hmmm...so a black bezel is much better? fooling the brain you might say?
  13. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    all panny panels have a black border to the glass panel........ the silver charcoal bit is just the casing.....more ambient light will reflcet of a silver bezel with possible detrent to picture quality tho...
  14. Hawklan
    Hawklan
    Oct 20, 2001
    6,744
    Essex
    +312
    Now this is interesting and may have been covered before
    But strolling around Selfridges looking at Plasmas (again!) - I actually asked one of the store staff to measure two plasmas
    a Panny 42 PW7 and some sony machine - Because the sony just looked so much bigger
    The PW7 had a visible image of just over 41" due to the black border within the glass which seems to be common with there range
    The sony visible image however was 42 and a half inches diagonal
    So are we back to the old CRT situation on the Panny range where even though the glass is 42" we loose a inch or so due to this black border
  15. Ekko Star
    Ekko Star
    Mar 18, 2002
    6,619
    London
    +468
    Exactly, the black bezel is in your periphery vision and fools the eye because it draws the contrast to the centre of the screen. Enhances the perceived contrast levels.
    Same principle applies to PJ screens which is why they have a black border and not just a blank piece of canvas.
    Strictly speaking, one screen is made for commercial purposes and one for consumer uses.
