Question Panasonic camcorder external mic for interviews
Discussion in 'Camcorders, Action Cams & Video Making Forum' started by Backinflow, Apr 15, 2019 at 8:22 PM.
  1. Affordable
    1 vote(s)
    100.0%
  2. Quality
    0 vote(s)
    0.0%
Multiple votes are allowed.
  1. Backinflow
    Backinflow
    Monday
    2
    London ( UK)
    Hello I just purchased a panasonic camcorder Full Hd Hc V - 770 and I need to get an external microphone. The purpose would be mainly interviews. Can anyone suggest a rather affordable yet good one?
  2. stearman65
    stearman65
    May 19, 2016
    430
    46
    England
    +206
  3. Backinflow
    Backinflow
    Monday
    2
    London ( UK)
    Thank you but I would be interested in a microphone that can be attached to the camera itself
  4. stearman65
    stearman65
    May 19, 2016
    430
    46
    England
    +206
    I have an Olympus LS10 which I've had for about 10 years, it's a recording mike so I get the LS10 recording & the camera's recording so I can cherry pick which is best. It can record in various modes including shotgun & various qualities. I've just found one on Amazon, didn't check if it was new as there are newer models. The Panasonic mikes are very expensive & have mixed reviews. I mostly rely on the cameras mike now with a good dead cat wind muff, just made one for my FZ330.
    https://www.amazon.co.uk/Olympus-LS...=olympus+ls10&qid=1555362267&s=gateway&sr=8-1
  5. JH4
    JH4
    May 6, 2003
    2,463
    83
    +299
    Rode shotgun mics. Brilliant ! ( With a wind gag, obviously. )
  6. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    28,603
    The Borders
    +3,495
    'The purpose would be mainly interviews' - are you planning to capture the Interviewer and the Interviewee with a single camera mounted mic?
    Joe
  7. Terfyn
    Terfyn
    Apr 19, 2013
    2,111
    North Wales UK
    +242
    For camera mounting I suggest a BOYA BY-VM190P short shotgun mic. (see www.boya-mic.com)
    But a camera mounted mic will capture all the noise between the interviewer and the camera. Better to use a mic, mounted on a stand or on a table between the speakers. i.e "rule of thumb" film from a distance but record audio close up.:thumbsup:
    It will depend very much on your situation. A controlled interview in a quiet room would benefit from a close up mic but you could get away with using the camera mics (in zoom mode). Connecting cables are not a problem in this situation.
    Recording passers by in a street is a very different matter. You could use a Lavalier (tie-clip) mic but a handheld would be better as you could aim it at the interviewee. The downside would be the connecting cable between the mic and the camera.
    I use a BOYA BY-WM5 radio mic. The receiver is mounted on the camera and the transmitter with the interviewer. I bought a second spare Lavalier mic and converted the original mic to a handheld with a bit of tube. Again a downside, town centres are cluttered with radio signals, Wi-Fi etc. so a sound test is required before recording.
    Finally (phew :facepalm:) a separate audio recorder such as a Tascam or Olympus is a popular option. You would need to sync up the video and audio in a video editor afterwards but that is relatively easy. People often use a handclap and align the video of the clap with the spike on the audio recording.
    You will see we share the same sorts of cameras. I now use the 800 mainly but keep the 750 for multi camera shoots. Again the video editor allows me to sync up the cameras in multi-camera mode.
