fluxo
I've had a look at the manual (VT30) and the calibration controls are very poorly
explained. Is there any other documentation from Panasonic that describes the
controls more thoroughly?
Some of the things I'd like to know:
In what order are the various controls applied to the input?
What are the units or scaling factors?
Where the manual says of R-Saturation "Adjusts the saturation of red area" what
does that mean exactly?
I presume it means rotating colour vectors that correspond to the "most red" point
for a certain IRE value (i.e., moving the vertices of the triangles that are
sometimes shown in chromaticity diagrams). I would also guess that some form
interpolation is used for secondaries etc., but where is the algorithm or
mathematical formula for that described?
Cheers.
Cheers.
