Panasonic BS850 won't always timer record
Discussion in 'Blu-ray & DVD Players & Recorders' started by Martin68, Feb 28, 2014.
  1. Martin68
    Martin68
    Feb 9, 2005
    449
    Swansea
    +19
    I have owned this bluray-hdd freesat recorder for a few years now, and every now and then timer recordings fail, the red recording light comes on a minute or so before the timed program starts, and it flashes until the program starts then the red is constant and recording is successful, but on occasion, the red light just keeps flashing all the way through to the end of the timed program, and the program fails to record.
    what could this problem be? is this common and it there a fix?
  2. Gavtech
    Gavtech
    Administrator
    Oct 25, 2005
    21,146
    +7,093
    I can only think that he broadcaster fails to send the start control code.
    The machine is sitting waiting for it - but it does not arrive.
    It would happen in the case of programme changes, or poor broadcasters.
    To this extent, note the channel involved when you get failures because the major broadcasters are very reliable but some secondary channels can be very poor.
  3. Martin68
    Martin68
    Feb 9, 2005
    449
    Swansea
    +19
    it was ITV1 Coronation street, but the red light dose come on but only keeps flashing, I didn't know theres a start signal, i thought it works by the machiens internal clock.
