Panasonic Bracket owners
Discussion in 'Home Cinema Buying & Building' started by Kazuya Mishima, May 14, 2003.
  1. Kazuya Mishima
    Kazuya Mishima
    Dec 11, 2002
    1,418
    North East Scotland
    +65
    Question for anyone with the official Panasonic bracket (for 42" Pansonic plasma displays):
    Which screws (and how many) are supplied with this bracket?
    I downloaded an installation guide for this and it mentions various bolts and screws....
    Thanks!
  2. SherrifJWPepper
    SherrifJWPepper
    From memory there are no screws or fixings supplied.
    I used about about 10 No.10 80mm screws straight through the plasterboard into the block work of the outside wall, spread around the bracket. Its solid as a rock :p
    You could use parabolts but I dont think its really neccessary
  3. Kazuya Mishima
    Kazuya Mishima
    Dec 11, 2002
    1,418
    North East Scotland
    +65
    Thanks SherrifJWPepper -
    The builders are fitting the bracket for me (all part of the service!) and I wanted to be able to tell them if there's any extra bits and pieces they'll need.
    Off to B & Q, then!
