It has to have an M button on it here are the instructions
1. Hold the ‘M' button (Key Magic) until the red light on the control blinks twice
2. On the remote press the buttons 994. The red light should blink twice.
3. Press ‘M' again. The red light will blink once more.
4. Enter the 5 digit function code.
5. Finally press the button you want to assign the function to. The red light will blink twice more.
Follow the above instructions to assign the following function codes to the following buttons:
key 1, code 00191
key 2, code 00120
key 3, code 00065
key 4, code 00180
key 5, code 00143
key 6, code 00155
key 7, code 00122
key 8, code 00117
key 9, code 00129
key 0, code 00123
Once all re-programmed we can now perform the multiregion procedure:
1. Switch on the player, eject any disc.
2. Press the OneForAll Remote buttons in the following sequence with about a second pause between presses: 1, 2, 3, 4, 5, 6, 7, 8, 9, 0
3. The player will automatically reboot and be DVD multiregion without any message.
Good luck and enjoy!
