Panasonic Best DVD-R's to use
Discussion in 'Blu-ray & DVD Players & Recorders' started by Ian C., May 5, 2005.
  1. Ian C.
    Ian C.
    Jul 8, 2004
    693
    28
    West Midlands
    +35
    Just thought I would start this thread about media
    for Panasonic recorders.I have so far used:TDK,Memorex,
    Mitsubishi,Bulkpaq Yellow all (4x)and not noticed any trouble
    on playback.I am only using them for short term recording
    and these have all done the job nicely.However I recently
    made my first online purchase of media and liked the look of
    these New 01ne Movie Stlye 4x http://www.ukdvdr.co.uk/shop/product.php?productid=17444&cat=291&page=1
    and these have been the first ones to have a problem.They record ok but on playback they tend to freeze or break up every now and then so I will not be using these again.The suppliers though seem very good(track your order etc)so I will be ordering off them again could anyone recommend any of the other 4x dvd-r's that they stock please http://www.ukdvdr.co.uk/shop/home.php?cat=291 :thumbsup:
  2. WhiteNoiseMaker
    WhiteNoiseMaker
    Mar 4, 2005
    42
    +4
    I use BlankDiscShop for my disc's. I always use blank DVDs that use a Ritek dye. i've used 1000's of Ritek dvds and i've not had one fail on me yet!
  3. Baron Von Doom
    Baron Von Doom
    Mar 15, 2005
    1,539
    worthing
    +137
    i got some star media dvd-r. bulk pack of 50. used about ten and had about eight fail. :mad:
  4. Ian C.
    Ian C.
    Jul 8, 2004
    693
    28
    West Midlands
    +35
    These last ones have also been saying check disc,
    and a couple of times recorder as gone onto standby,
    I will probably go for Ritek next cheers for the tip.
  5. musukebba
    musukebba
    Jan 11, 2005
    689
    +16
    Buying discs by brand is usually going to be a lottery. Get your discs from a retailer who quotes the media code, and look up the good and bad ones here.
  6. Rasczak
    Rasczak
    Apr 3, 2002
    21,687
    Warwick
    +2,560
    But be aware of the millions of cheap discs that use one of these codes to improve their compatibility with other burners - it doesn't make them top media and frequently indicated the complete opposite.
    Stick to buying discs from disc producers such as Verbatim, TDK, Maxell and you know you are getting a reasonable product. Ultimately you are significantly safer archiving to two or more discs of different makes than looking for the 'perfect disc' - there is no such thing!
  7. JML
    JML
    No manufacturer produces disks perfectly 100% and faults may appear in a particular batch. If you want to archive, do as Rasczak suggest however use disks from two different manufacturers this will significantly reduce the risks.
  8. musukebba
    musukebba
    Jan 11, 2005
    689
    +16
    If this is another way of saying they're fakes, then yes. In my experience, the retailers who do quote the dye identification as lead-in or media code take care to get their stock from genuine sources. As highlighted above, SVP are a first-class example.
    I would have thought this is mainly because they invariably use a reliable dye.
  9. Struan
    Struan
    Aug 24, 2002
    155
    Scotland
    When I had the E95, I used circa 80 No. Taiyo Yuden 8x from SVP, with a 100% burn record. (I didn't know until after I got the discs that the E95 only has a 4x drive!)
  10. TobyW
    TobyW
    Jan 6, 2005
    157
    Australia
    +3
    I've just discovered how to read the media ID off a disk, with Nero. Just run Nero ->T oolkit -> Nero CD Speed, and click on Extra -> Disk Info.
    I've got a bunch of disks, some of which have visible dye defects, and some of which have become unreadable a couple of months after being burnt. The disks carry no brand name, but the media ID reads as "Maxell MXL RG01". In the guide at http://www.digitalfaq.com/media/dvdmedia.htm, this ID is listed as "1st class media", but I suspect it's really in the "unbranded fakes" category, also mentioned in that guide.
    I've learnt a lesson. I thought I would share it.
  11. musukebba
    musukebba
    Jan 11, 2005
    689
    +16
    They could be fake, but also genuine Maxells that were factory rejects and found their way onto the market. With visible evidence like that, you certainly have grounds for a refund from the retailer.
    It happens to us all, even with the best buying strategy. I found several genuine Ritek G04s in a spindle which had the same visible streaking and found out too late that they were unreadable right from the off. Nevertheless SVP replaced the whole spindle without question - the other 3 that I bought were fine.
