Panasonic Background only grey?
Discussion in 'Panasonic TVs Forum' started by scooter41, Mar 15, 2005.
  1. scooter41
    scooter41
    Feb 16, 2005
    38
    Hi There,
    I have recently purchased the HD 42" panasonic, and I am about to show a client a 4:3 dvd on the screen......... either I have been stupid and missed in the manual, or am I unable to change the horrible grey background of the screen??
    At the moment the picture looks funny with light grey bars either side, and I would much prefer black...
    Anyone know if this is possible?
    Thanks in advance
    Scott
  2. Bearded_Malc
    Bearded_Malc
    Aug 10, 2004
    393
    +20
    Isn't that a setting in the screen saver section? The light grey is so that in 4:3 or 2.35:1 the black edges don't burn into the screen. It would be wise to run the screen in before making them black. Even then dark grey would be less risk. Or you could use Just mode.
  3. Tarsh
    Tarsh
    Jan 9, 2005
    52
    9
    Essex
    Hi Scooter,
    You need to adjust the screensaver, side panel setting.
    Pages 26 - 28 of the manual :lesson: , details in case you don't have it:
    Press setup on your remote
    Scroll down to screensaver
    Press the centre button to select
    scroll down to Side panel
    Use left or right to change setting (Off, Low, Med, High)
    It is recommended to keep this low while running in, but I'm sure it will be ok to have it set to 'Off' for a demo.
  4. TeresaTT
    TeresaTT
    Sep 11, 2004
    508
    Walsall
    +13
    The Panasonic grey bars only apply to 4:3 pictures. The black bars at the top and bottom of 2.35:1 pictures come from the source and are nothing to do with the screen. The only way to change these bars would be if there were such a feature on the DVD player.
  5. Bearded_Malc
    Bearded_Malc
    Aug 10, 2004
    393
    +20
    Of course, note to self put brain in gear before engaging mouth (or keyboard).
  6. MAW
    MAW
    Jan 24, 2002
    14,103
    Nr Dorking
    +411
    That happens to all of us from time to time! You're in good company.
  7. Brooktop
    Brooktop
    Feb 2, 2005
    2,103
    Nottingham
    +93
    Generally 'just' mode works fine for most pics and it's less distracting than side bars
  8. shaithis
    shaithis
    Feb 25, 2005
    1,668
    The Last Aerie
    +31
    Does that mean the top and bottom black bars are excempt from the "burn in" problems or just that you cant do anything about them?
  9. Steve_P
    Steve_P
    Jul 3, 2004
    1,338
    67
    +142
    They are NOT exempt, as you say, "you can't do anything about them" short of zooming the picture to fill the screen, some AV diehards will cringe at that suggestion mind ;)
    S.
  10. Mep
    Mep
    Dec 25, 2004
    9,673
    Surrey
    +477
    the latter I think, best avoided if you are concerned about burn in during the running in period
  11. scooter41
    scooter41
    Feb 16, 2005
    38
    Hey guys thanks for the reply, I thought it must just be me being stupid :)
    Thanks for the tip!
    (Off i run to try it now.........)
