Panasonic - AV on power On
Discussion in 'General TV Discussions Forum' started by tikki, Sep 19, 2003.
Tags:
  1. tikki
    tikki
    Sep 19, 2003
    4
    Panasonic TX 32PG 50
    Been through the manual and menus but I can't find if its possible, when turning the TV on, to automatically have the Input from SKY instead of the RF aerial.
    As it is, I have to select the AV input once the TV Is on.
    Is there a way around this
    Thanks for any help
    tikki :rolleyes: :eek:
  2. shawkins002
    shawkins002
    Dec 12, 2002
    236
    Epsom, Surrey
    No. Never have been able to do this on Panasonics - it's annoying. The TV always defaults to a terrestrial channel when first switched on.
    You could always buy a pronto and have a macro to do this......
  3. tikki
    tikki
    Sep 19, 2003
    4
    Thanks for that.....
    Thanks for that.
    Actually, I do have a Pronto but It doesn't always switch to AV.
    I probably need to lengthen the delay between Power On and switching to AV
    tikki
  4. nathan_silly
    nathan_silly
    I used to have a Panasonic TV- dunno if new one's are the same. Do you have to press AV Select then one of the Red/Green/Blue/Yellow buttons?
    You could do a macro that presses AV than Red.. that will go to AV1 (RGB SCART)
