panasonic auto mode
Discussion in 'Televisions' started by petebog, Dec 19, 2003.
Tags:
  1. petebog
    petebog
    Is there anyway to stop the panasonic auto mode from zooming in on certain channels and keep it on just mode. Don't want to use 16:9 for 4:3 channels as they're too squashed.
    TV = panasonic tx32ps5
    Thanks for any help:)
  2. Loada
    Loada
    Mar 4, 2003
    585
    Guisborough, North Yorkshire
    +48
    I might be missing something here, but can't you just use the "Aspect" button to set the TV into "Just" mode (instead of "Auto")? The TV should remember that setting until you change it again.
    I have a Panasonic 32PF10 - I just leave it in "Full" mode - most channels (on Sky+) broadcast in widescreen anyway.
  3. petebog
    petebog
    The tv only has panasonic auto, 16:9, 14:9, 4:3, zoom1 and zoom 2. Just mode is part of Panasonic auto mode and can't be selected individually, but if a 4:3 broadcast has black bars at top and bottom, the tv zooms in on the picture and all graphics and writing on the picture dissappear.
    so i was wondering if there was a way to make it stay in just mode
  4. mjcairney
    mjcairney
    Oct 26, 2003
    6,881
    2
    4
    137
    Airdrie, Scotland
    +849
    I have a Panasonic TX-W32D2 and can choose either Just Mode or Panasonic Auto - are you sure you can't do the same?
  5. petebog
    petebog
    yes i'm positive, there is no just mode except as part of the panasonic auto mode.
  6. alfablue
    alfablue
    Aug 16, 2002
    287
    19
    I generally use the 16:9 mode, this works fine for digital broadcasts, most fill the screen, and it wont automatically adjust if there is a black bar, or as sometimes happens, when there is a dark scene, as when in auto mode.
    The other mode I tend to use is zoom, which I can control, and I use this on the rare occasions I am watching an analogue broadcast (happens only when I am videoing something else on a digi channel).
    The Auto and Just modes (which seem to be the same?) are just annoying, especially with ad breaks which often don't fill the entire screen and prompt a response from the TV
  7. Kahless725
    Kahless725
    I have a Panasonic TX28PK1 which is a 4 y/o Flatscreen set with a quintrix tube and that has a just mode. I have just got a new TX28PS12 which has done away with the just mode and included it in the auto, I must admit I never used the just mode just the auto so it isnt somthing I am going to miss.
    Just though i would write and confirm what you are saying.
    Robert.
  8. sc0tsman
    sc0tsman
    Jan 19, 2004
    7
    yes i have the same problem here and it is really really anoying i have tried everything to no avail ie. sky digi box settings @ rgb widescreen dvd recorder @ rgb widescreen dvd player @ widescreen
    any help would be very gratefull
  9. Phil_S
    Phil_S
    I had a TX32DT30, and found that if I left it in 4:3 mode it would switch automatically between 16:9 and 4:3 according to the aspect ratio of the broadcast program.
  10. petebog
    petebog
    put the tv in 16:9, when a widescreen broadcast happens the tv will switch to wide. You can tell this by pressing the info button and it should say wide.
