Panasonic AS650B
MrMav11
Can someone help on what these specs mean on the Panasonic AS650B please, and anyone know what the below are.
• Panel Drive - 1200 Hz BLS IFC
• Content Optimiser - Content Optimiser Plus
• Contrast - Brilliant Contrast
In game mode what is the lag?
jetman
1200Hz BLS IFC = backlight scanning intelligent frame creation
This is the motion processing rate, in general the higher the figure the more stable and clear moving images will be displayed on your tv.
MrMav11
It's not "really" 1200Hz though is it (I've since found out), as it's all with the manufacturers own sooper dooper tech rather than a raw figure I believe?
So although I don't know much, is backlight better than edge or an I wrong in that thinking?
jetman
Yes, that's right - the processing rate is derived from whatever algorithm the manufacturer works out (makes up) and that makes it difficult to compare across different brands.
There is a potential danger here of confusing Panasonics 'backlight scanning' name for their processing software with direct lit versus edge lit LED hardware. I think most people would agree that direct lit LED more reliably achieves an even and uniform picture than edge lit, the only down side is that direct lit screens are not quite so thin.
MrMav11
Ok thanks, wonder what the real refresh rate is for reference then.
So is the AS650B direct backlit or edge lit? Still confused!?!
