Panasonic Announces PT-AX200 and PT-AX2000 Projectors
Discussion in 'Projectors, Screens & Video Processors' started by jstanton8869, Sep 1, 2007.
  1. jstanton8869
    jstanton8869
    May 5, 2007
    23
    3
  2. pal
    pal
    May 27, 2003
    183
    coventry
    +14
    Well spotted.... i've googling for these this afternoon...should just have come directly onto the forum!
    Some mention that the AE2000 will be displayed in a glass cabinet at Cedia in the US within the next few weeks..where hopefully specs will be available.
  3. ianmacd
    ianmacd
    Jul 5, 2007
    1,013
    48
    +80
    I ordered an AX100 on Thursday for £699 (my first PJ). Doubt they will go much lower than that (well I hope not).
    Hopefully, it will arrive Monday but more likely Tuesday.
  4. JustJB
    JustJB
    I was considering my first PJ to be a AE1000, do you's think there will be much of a price drop on them? If so, does it usually happen just before the release, or a good while after (generally).
    Cheers.
  5. Pumauk
    Pumauk
    Nov 30, 2005
    968
    +16
    Where was the ax100 £699 from?
  6. jstanton8869
    jstanton8869
    May 5, 2007
    23
    3
    http://www.komplett.co.uk/k/ki.aspx?sku=326377
    has it for £699 with stock arriving later this week - not sure it's true UK stock though
    http://www.discounttv.co.uk/category/LCD+Projectors/product/Panasonic_PTAX100_Projector.html
    have it for £739 guaranteed UK stock and cheap extended warranty
    but
    http://www.digitaldirect.co.uk/products_moreinfo3/index.asp?product_id=11794
    have it for £684 :clap:
    I'm not getting my garage converted until the end of the year ......do I buy now or wait for the AX200??
    Interestingly the new Aussie RRP for the AX200 is LOWER than the Aussie RRP for the AX100 so it would suggest that the AX200 will arrive here at a lower price point.....maybe.....Rip Off Britain etc etc
    John
  7. Pumauk
    Pumauk
    Nov 30, 2005
    968
    +16
    Is the Panasonic ax100 much better than the Sanyo Z5? Both arund the same price it seems.
  8. Alhambra
    Alhambra
    Jan 25, 2005
    49
  9. sapkan
    sapkan
    Jul 8, 2004
    496
    +4
    I think the Sanyo is better.
  10. nigel77
    nigel77
    Jan 19, 2007
    727
    Devon
    +31
    tottally agree. I'd put my money on the Z2000
  11. PAUL_M01
    PAUL_M01
    Jul 25, 2006
    202
    Got any details?
    Or is this sarcasm?
  12. MI55ION
    MI55ION
    Nov 8, 2005
    5,851
    +690
    How does the Sanyo (Z5?) handle screen door and 1080p/24 signal?
  13. Rob100
    Rob100
    Nov 3, 2002
    3,485
    +227
    If you're not ready I'd wait as there's always something bigger/better/cheaper round the corner. The price of PJ's seems to drop like a stone.
    Just read that Australian site and I quote...
    "'Light Harmonizer II' system to set the image to suit ambient light levels. It's a wanky name"
    Strange description and not sure if appropriate language? Maybe it means something else down under...
  14. nigel77
    nigel77
    Jan 19, 2007
    727
    Devon
    +31
  15. ventolin
    ventolin
    Jul 26, 2007
    5
    3
    This is great new for those of us who've been watching with baited breath the PT-AX100's dropping in price too.
    The Z2000 is a Sharp projector, not a Sanyo, right? <<--- my bad, looks like both Sharp AND Sanyo make a Z2000 now, what the - ?
    As for the Z5, it has screen door and handles 1080p/24 like most other 720p projectors - with 3/2 pulldown. The PT-AX100 is one of the few that handles it without pulldown... I guess this doesn't bother a lot of people, but personally I wanna see Planet Earth slide smoothly across my wall.
  16. Pumauk
    Pumauk
    Nov 30, 2005
    968
    +16
    Is the screendoor on the Sanyo bad then? I was under the impression sde isnt actually that bad anymore...
  17. nigel77
    nigel77
    Jan 19, 2007
    727
    Devon
    +31
    Screendoor really isn't a problem on projectors that are 720p or higher unless your sitting closer then 1.5 times the screen width.
  18. smartbodydublin
    smartbodydublin
    Jan 23, 2006
    28
    3
    I'm using the ax100e since since march, have about 300 hrs on it. Viewing it on 106" screen. There is no screen door unless you are right up to the screen. I'm using stardard definition dvd, so can't comment on how good the ax100 is with hi def 720, but on standard def dvd, it's fantastic to me.
    Stardard definition digital tv is ok to poor, unless screen size is zoomed down to 90" or less, but that's to be exspected. Bought from Discount tv with extended guarentee.
    Compared to what I paid for a much lower resolution projector 4 years ago, it's amazing what you can get now.
  19. dun_buyin
    dun_buyin
    Feb 28, 2007
    191
    28
    +31
    Thought I'd revive this thread now that the PT-AE1000 and AX100 seem to have all but sold out now and the AX200 is showing as available from Roy Jowett at £999. Personally looking forward to the AE2000 after seeing an AE1000 in action and being suitably impressed by the pq and the icing on the cake for me was the extensive lens shift. It is also nice and small compared to other 1080p units. (nearly bought one there and then!)
    Some details have been available here for a while http://panasonic.co.jp/pavc/global/projector/products/ae2000/index.html
  20. dun_buyin
    dun_buyin
    Feb 28, 2007
    191
    28
    +31
  21. dun_buyin
    dun_buyin
    Feb 28, 2007
    191
    28
    +31
  22. Member 55145
    Member 55145
    Jan 18, 2005
    12,082
    +3,483
    probably has more to do with the fact that Australians dont get wound up in PC like we do. remember that "where the hell are ya?" advert? made us look like idiots
    personally i preffer it when a reviewer "tells it like it is" and i havent heard the term "wanky" in years lol
    love it!
  23. Fangorn
    Fangorn
    Nov 9, 2003
    566
    28
    UK
    +28
    Think I read somewhere the PT-AX200 has an increase in shapness over the PT-AX100.....
  24. Shockabuku
    Shockabuku
    Mar 5, 2002
    1,809
    Oxfordshire
    +170
    Early review of the PT-AE2000 here. It's translated from German so not super easy to follow, but you can get the general impression. European RRP is allegedly going to be 2600 euros.
  25. gandley
    gandley
    Aug 31, 2003
    5,102
    Paradise Lost
    +269
    Impressive native contrast for an LCD (AE2000 that is). Some of the improvements really are nice, and some great user features. 3HDMI inputs is sweet.
    Cine4Home guy posted on AVS that while the Sanyo Z2000 has potential, it is currently disappointing, mainly due to still not improving the dynamic iris over the Z5.
    out of the new crop of LCDs so far it looks like the Panny and the epson are the choice pick. HC6000 seems a tad behind the panny, but price may make it a good deal.
    looking forward to the reviews.
