Panasonic and Sony Projection Screens
Discussion in 'Projectors, Screens & Video Processors' started by lscolman, Jul 15, 2004.
  1. lscolman
    lscolman
    Jul 31, 2003
    7,145
    Tyne & Wear
    +151
    Looking for some advice on which starter screen is better between the Panasonic 72" (£80) or the Sony 70" (£100). Both are available from Techtronics.
    Could anyone who has had these screens advise please?
    Thanks in advance
    Lee
  2. Fonzerelli
    Fonzerelli
    Jan 19, 2004
    159
  3. lscolman
    lscolman
    Jul 31, 2003
    7,145
    Tyne & Wear
    +151
    Hi Fonzy,
    Looking at their web site the equivalent models (Easy range) start from £376!
    Can you advise why these screens are good? I just bought a Sanyo Z1 and would like a screen which will do a good job for me.
    Cheers, Lee
  4. AMc
    AMc
    Nov 20, 2000
    6,947
    Near Norwich
    +3,552
    If I understand correctly the DRH Easy range are portable, collapseable/self supporting designed to be packed away when not in use.
    The screens at http://www.techtronics.com/uk/shop/6593-000-screens.html (apart from being poorly illustrated and described) are described as 'manual' and 'pull down' which means they are designed to be attached to the wall or ceiling and rolled down like a roller blind. These are closer to the slimline or regular at DRH which are very similar in price to the ones you've looked at.
  5. Fonzerelli
    Fonzerelli
    Jan 19, 2004
    159
    Lee as AMC said its the easy range you want to be looking at, i got mine from them and i have to say its absolutley fantastic for the money, build quality is spot on and picture from my PTAE300 is simply superb. other makes to look at are draper and bemaxxed who all do budget screens :)
