Panasonic and SKY+ HELP!!!!!!!
Discussion in 'Panasonic TVs Forum' started by marky1975, Aug 20, 2005.
  1. marky1975
    marky1975
    Dec 27, 2004
    65
    romford/essex
    Hi I need Help im quite new to av stuff but here goes
    i have a panasonic pw4 plasma with RGB/COMPONET IN and tunner box which im getting rid off.
    i want to direct link from a sky + box to the pw4 in componet.
    as sky box isnt componet i have brought a RGB Scart to componet converter from keene.
    i have made sure the sky box outputs RGB and i have set the plasma to componet in.
    but nothing displays on screen apart from NO SIGINAL on the plasma screen.
    also am i right in saying that using component i dont need to use the HD,VD leads that pluged in to plasma from my tuner box that im doing away with.
    Hope some one can help
    MArk
  2. Parklife
    Parklife
    Jun 9, 2004
    566
    28
    +33
    I think if you have the tuner card in then all other imputs are disabled. Try taking the tuner card out.
