Panasonic AE900 Price Drop - When?
Gadgetgeezer
Question as per title. Have built my home cinema but currently saving for this projector. Have heard that the price will drop, but anybody know when or by how much?
Regards
Spencer
KelvinS1965
Just seen it on sound and vision for £899 which is about £120 less than the last time I looked. I was saving up for one, but decided to get a larger main TV instead.......
Hope this helps:thumbsup:
VirusKiller
We're expecting (hoping?) that a new Panny model will be announced at Cedia in September, so that may cue the stock clearances...
benji_m
Retailers are below £trade as it is on the AE900.
My guess and my feeling from talking to Panasonic is they will just shop shipping the 900 a few months before the next one puts in an appearance!
infinite_loop
sorry to butt in on an AE900 thread, but I see you're a Themescene dealer....
have you any idea why I can't see the DCDi menu on my HD72i, whichever input i'm on? I'm feeding it Sky HD via HDMI and progressive DVD component, so i'm not surprised it's hidden on 576p sources, but when it's 1080i I should see it, don't you think?
VirusKiller
IIRC, DCDi is only a SD deinterlacing piece of functionality, so it won't be applied to 1080i sources (shame!). Try feeding the PJ a 576i signal to see if the menu appears...
VirusKiller
So what's the deal Ben? This doesn't make sense for anyone (apart from happy Panny bargain hunters...).
Edit: I'm currently waiting for the Cedia announcements, but heck, I must admit I'm tempted to drop a grand on an AE900...
michael.redfern
£885 delivered from Digital Direct. Admittedly you don't get the pixel check etc that DiscountAV/RoyJowett/Ivojo etc give, but much cheapness.
infinite_loop
ahhh... I did wonder. I can't get a 576i feed outta my Sky HDMI connector...i'd need to do some kind of Scart RGB-VGA adaptor nonsense. I wish I knew it would be worth it! I'll force my DVD to interlace on the component to see how good it is or isn't . Ta!
VirusKiller
You can get 576i out of the Thomson SkyHD box if you can edit the EDID list. I'm not sure if this can be done with the Panny. There's a longish current thread in the Scaler / Prog Scan forum.
benji_m
Indeed,
Having knowledge of roughly what other dealers pay for things, it's a suicidal price that can only benefit consumers. Assuming they have them and assuming they are UK (stock is tight atm) then that's a good initial deal for that model.
You can't be the absolute cheapest all the time :)
VirusKiller
Thanks Ben. Veering slightly OT, what's the VB and panel uniformity like on the AE900 these days?
neeek
Hmm.. This one's a bit tricky. If the AE1100 is 1080p and around £1500, then I definitely want one. But what happens if it isn't and stock of the AE900 runs out in the meantime? Sweaty palms time...
N
nickn5
Now on Sound and Vision AND Digital Direct for £885 delivered... seems like a good time to get it... :thumbsup:
N. :)
benji_m
Same company same stock I belive :)
Everything has been universally problem free on the 900 as far as I am aware. No real VB to speak of, and panel allignment is fine!
Podcast: CES '22 TV Announcement Round-up, Plus, Most Anticipated Movies of 2022 and More...
