Panasonic AE900 PC over HDMI?
Discussion in 'Projectors, Screens & Video Processors' started by GPMCDERM, Mar 19, 2006.
  1. GPMCDERM
    GPMCDERM
    Dec 12, 2002
    109
    I've tried using the HDMI connection on my AE900 for the PC...problem
    is that it shows a picture when booting up but them goes blank...funny
    thin is that if you connect using the vga input and then swab the
    cables to DVI->HDMI it displays no problem and it way better picture than the normal vga. (Even reports monitor as AE900)
    I'm using a 98pro AIW.....the 720p QT7 trailers are a joy...only high def
    stuff apart from the 360 at the moment. Any ideas would be great.
