Panasonic AE700 - HDMI - best picture settings
Discussion in 'Projectors, Screens & Video Processors' started by paulmcp2403, Aug 5, 2005.
  1. paulmcp2403
    paulmcp2403
    Mar 29, 2005
    1,357
    +142
    does anyone have any preferred settings for this projector when running via HDMI as opposeded to the factory presets...??
    please post :O)
  2. Sigismund
    Sigismund
    Jan 14, 2003
    5,535
    London
    +102
    Hi there.
    I have an AE700 and a number of DVD players - a Sony DVP-NS900V, Limit DVD900SE, Panasonic S97 and Philips DVP9000 - the last two connected via HDMI. The thing is I have different settings for each player, so it really is necessary to set up your DVD player and PJ using something like Digital Video Essentials in order to obtain the best image with your particular DVD player/PJ combo.
    As an aside, I have found that using a filter - I have a B+W 81EF 77mm - definitely improves contrast and gives me a much more "solid" looking image. Well worth the money, but it does require quite a bit of tweaking with the projector's picture adjustments!
    Using this filter means that the best image quality is obtained when setting the Panny to Video mode and using the High Bulb output. Now I've experienced the overall improvement I wouldn't want to go back to Natural or Cinema 1 modes without the filter! ;)
  3. Mark_a
    Mark_a
    May 27, 2005
    3,079
    +623
    Make sure you can live with the fan noise of a projector bulb set to high.
    Regards
    Mark
  4. paulmcp2403
    paulmcp2403
    Mar 29, 2005
    1,357
    +142
    cheers mark - where do I get Digital Video Essentials ???
  5. Sigismund
    Sigismund
    Jan 14, 2003
    5,535
    London
    +102
    Movietyme have the NTSC disc, but if you want the Pal disc I'm not sure... try a search from the retailers listed here :)
