panasonic ae700 flickering
Discussion in 'Projectors, Screens & Video Processors' started by bluesilver, Mar 20, 2006.
  1. bluesilver
    bluesilver
    Jun 24, 2005
    447
    28
    Poole
    +55
    hi all,
    I've noticed that my ae700 pj flickers fairly often. From what I searched on here, it seems some people have had it too, but I don't know if anyone has found out why it happens or how to fix it.
    Anyone got any ideas?
    thanks:lease:
  2. pez
    pez
    May 1, 2004
    776
    Newport
    +27
    Panasonic took a look at my ae500 twice and said they couldnt see it.
    its not so visible during movies, especially if i place the projector a long way from the screen and go uber big with the image, but if its a relatively small screen that im projecting onto, then i can generally make it out.
    very annoying.
    pez
  3. bluesilver
    bluesilver
    Jun 24, 2005
    447
    28
    Poole
    +55
    cheers pez.
    it is werid, the whole picture just flickers for a second or two, sometimes with a couple of other flickers within quick succession, sometime it doesn't happen for another 30 minutes.
    This seems to happen just with dvds, but that I don't watch that much tv through it so it could happen then too.
  4. paulmcp2403
    paulmcp2403
    Mar 29, 2005
    1,367
    +149
    hi,
    try checking all connections...I know it sounds ridiculously simple...but it oftne works...also power the unit down fully at the mains and restart. Check for any sources of electrical interference....strange ...but it happens...
    We cna take it form there.
    ps - Q - what conention are you using - scart, hdmi etc...?
  5. pmc
    pmc
    Oct 18, 2004
    1,414
    +104
    I had this after about 800 hours on the lamp. I found some references on here that said to leave it running for 12-16 hours continously. I watched 3-4 movies on the trot one night, lasting 9-10 hours and viola, the flickering disappeared. :cool:
    Apparantelly its got something to do with material building up on the inside of the bulb causing arcing. Running it for a really long time burns of the excess material.
    Now at 1100 hours and it's started again so am preparing to do another long session. I am concerned though that eventually this isn't going to work as its an indication the bulb is on its last legs.
  6. Nikumba
    Nikumba
    Aug 20, 2004
    231
    +9
    Are you watching DVDs through HDMI?? If so find out what firmware you are using if it is beliw 1.07 get a call into Panasonic qnd tell them you have hdmi flicker, they pick it up give new firmware and that should stop the problem
    Nikumba
