Panasonic AE700 firmware upgrade
Discussion in 'Projectors, Screens & Video Processors' started by mamoulian, May 16, 2005.
  1. mamoulian
    mamoulian
    Nov 9, 2004
    11
    Can the upgrade to 1.07 be done at an authorised Panasonic service centre, or will they ship it off to Panasonic to get it done?
    I've only been able to speak to receptionists so far, who don't seem to know what firmware is...
    Neil
  2. hrc4u
    hrc4u
    Jan 24, 2005
    5
  3. OneEyedStuart
    OneEyedStuart
    Oct 12, 2003
    4,872
    Falkirk, Scotland
    +833
    I belive that a service centre will in turn ship back to Panasonic. You are best dealing with Panasonic directly yourself. You will be able to find contact details in this forum if you do a wee search.
    As for upgrading the firmware yourself then that is of course your choice. If it was me I would give it a miss. Its not like dropping a burnt firmware CD into a DVD player. You would have to open up your AE700 and therefore void any warranty, and then trawl through the French website which hrc4u gave. Just the piccies of the wiring diagrams put me right off that one. Flashing firmware is a brown trousers affair at the best of times, no point in making it any more stressful than it has to be.
    Panasonic don't keep the projector for long, mine was back to me in exactly one weeks time, so I feel it's best for you to send it away.
    Regards
    Keith Hurst
  4. FoxyMulder
    FoxyMulder
    You do not have to open up your Panasonic Projector to update the firmware.
    There is a second hidden menu on the projector to access it you go into the first hidden menu and then select HD Overscan and then hold down enter for 3 seconds, this gives you access to the second hidden menu from which you can select to access the RS232 port thru the PC D-Sub 15 pin input.
    Maybe i'm missing something here but i would imagine Panasonic do it this way too and do not open anyones projector up.
  5. OneEyedStuart
    OneEyedStuart
    Oct 12, 2003
    4,872
    Falkirk, Scotland
    +833
    OK I can see that this makes sense.
    Would I still do it though, probably not. It just seems a lot easier and safer to allow Panasonic to do the upgrade, especially as they don't keep it for too long and secondly currently I can't get BableFish to translate the submitted French website lol.
    What sort of kit do you need to fire the firmware into the D-Sub ?
    Regards
    Keith Hurst
  6. AVmaster
    AVmaster
    Dec 12, 2004
    381
    Liecestershire
    What does the new firmware correct and how do I check which mine has?
  7. hrc4u
    hrc4u
    Jan 24, 2005
    5
  8. thfccambs
    thfccambs
    Jul 17, 2002
    18,984
    White Hart Lane
    +5,043
    Menu
    options
    hold OSD down for 5 secs,another menu should appear
    press self check
    Should be the 1st R number 1.03 1.05 or 1.07
    Sure thats correct.
  9. AVmaster
    AVmaster
    Dec 12, 2004
    381
    Liecestershire
    Got it.
    So what does all this mean?
    [​IMG]
  10. thfccambs
    thfccambs
    Jul 17, 2002
    18,984
    White Hart Lane
    +5,043
    Firmware 1.03
