Panasonic AE700 Color Calibration
Discussion in 'Projectors, Screens & Video Processors' started by jjdaugh, Apr 24, 2005.
  1. jjdaugh
    jjdaugh
    I have a Hitachi CRT television that lets you adjust the color using a grid. The lines are white and if you see the blue, red or green outside the white line you can adjust that color until it disappears behind the white line.
    I noticed on my AE700 that I can see the red and blue outside the white lines when going into a setup menu. I cannot find anywhere to ajust or calibrate these colors.
    Anyone know of a way to do this or is this a service requirement?
    Thanks,
    Jim D
  2. CooperUK
    CooperUK
    Jun 30, 2003
    2,186
    Hampshire
    +295
    Sounds like your panels aren't set right, on mine I can't see any colours separately - contact Panny for service/replacement.
  3. Sigismund
    Sigismund
    Jan 14, 2003
    5,408
    London
    +102
    cine4home's review of the AE700 suggests that using the Panny's lens shift abilities can throw out convergence so that might be worth checking :)
