panasonic ae500 not working
Discussion in 'Projectors, Screens & Video Processors' started by eddiethehead, Jul 29, 2004.
  1. eddiethehead
    eddiethehead
    Feb 21, 2004
    137
    london
    +7
    I bought a Panasonic ae500 LCD projector back in January, and it's been perfect up until now. But on Wednesday, it just packed up. When i power it up, the power light flashes as usual, then stays lit for a few seconds, then starts flashing again, at the same time, the lamp indicator flashes. At no time does the lamp come on at all.
    Does it sound like the lamp has blown? I was under the impression that the lamps dimmed gradually (which mine didn't). It only had about 800 hours use on low setting.
    Any advice gratefully received.
    Mark.
  2. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    8 months is within waranty so get it sent away but be prepared to pay for a new bulb.
  3. eddiethehead
    eddiethehead
    Feb 21, 2004
    137
    london
    +7
    Does it sound like a fault with the machine, or was i just unlucky to get a duff bulb?
  4. Kramer
    Kramer
    No real reliability problems reported with the AE500 so I'd say it's just the lamp.
    Best of luck with it.
    :smoke:
  5. eddiethehead
    eddiethehead
    Feb 21, 2004
    137
    london
    +7
    Cheers.
    Anyone know of places selling lamps cheap at the mo?
  6. Kramer
    Kramer
    PJ lamps are never cheap :(
    Probably worth a search here though. IIRC someone posted a link some time ago.......
    I'd get it back to Panasonic & argue with them. Probably your best bet of getting a "deal" on a replacement lamp.
    :smoke:
  7. Neo 74
    Neo 74
    Does anyone know where you can buy the panasonic pt-ae500e lamp in United Kingdom. I dont want to send of the pj to pany I would rather fit it myself..
  8. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    not consumer, but a local dealer will fit a lamp for you, perhaps supply one.
  9. Neo 74
    Neo 74
    do you know how much the lamp will cost from that local dealer?
  10. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    erm no, just give a few a ring and get some quotes.
  11. sirp
    sirp
    Jan 20, 2002
    891
    28
    Derby
    +53
    my ae300 was 11 months old, i complained of brightness flicker, and got a new bulb no problem for free....a bulb should last for at least 12 months, or X amount of hours..thats what i would argue
  12. eddiethehead
    eddiethehead
    Feb 21, 2004
    137
    london
    +7
    Finally got my ae500 back after nearly six weeks! (but thats another story), and it turns out the service agent i took it to, replaced the lamp, which promptly blew, then sent it back to Panasonic who had to replace some power supply components. Was this the same problem loads of ae100's had?
    Now to try and get my £350 for the new lamp back.
  13. eddiethehead
    eddiethehead
    Feb 21, 2004
    137
    london
    +7
    Got a refund from Panasonic today for the full £350 :clap:
    On a more worrying note however, since getting the pj back, i've noticed that it gets extremely hot (hotter than before it broke down), and yesterday i even had the "Temp" light flashing after about 6 hours use in a room with no heating, and with a fan pointing directly at it from about 2' :confused:
  14. pantages
    pantages
    Jan 7, 2004
    959
    2
    Boston
    +61
    There is instruction in the user manual on how to replace a lamp.
