Quantcast
Panasonic AE500 and Sky+?
armxz02
Ok Guys, I needs some advice...
In the very near future I will need to connect my Panasonic AE500 (located in the new upstairs loft) to my Sky+ v1 box (located downstairs - front room).
What is the best method to connect both of these devices and maintaining a reasonable picture quality?
Assumptions -
Sky+ box is already connected downstairs to my Marantz amp via optical (and I assume the picture is coming from the scart)
My Denon 3803 is also located in the loft with my ae500
I am prepared to install the necessary cables from downstairs into the loft.
Can anyone recommend the best solution ?
How have you guys connected Sky+ with your Ae500?
Help :lease:
SamirP
you always use the s-video output from your sky + box to connect to your ae500. I would have thought that this would be your best option
Or you could get a second sky box for the loft and then just connect via rgb scart I think that this would give you the best picture.
How far is the cable run going to be if you connect form the downstairs sky box to the loft?
armxz02
Hi Samir
The distance between the rooms is probably approx 20-25ft
Does S-video only carry video signals or both video and audio?
How can I forward the audio to my Denon 3803 receiver?
I'm not too keen on paying for another Sky box/subsciption
:confused:
SamirP
Originally posted by armxz02
Hi Samir
:confused:
S-video only carries a video signal.
To carry the audio signal to your 3803 just use a set of phono cables
10m S-video & 10m set of phonos would be fine
S
squealer
I personally found RGB Scart to be way clearer and brighter than S-Video (over a 10mtr run) - no way I would use S-Video after seeing the difference.
The only hassle is having to have a switch box so you can view RGB thru normal TV as well.
lonestar
... or how about taking scart from skybox to a rgb-convertor and then component from rgb-convertor to pj ?
NonPayingMember
Previously Liam @ Prog AV
Or simpler to use scart distrubution amp and gain two RGB scart outputs, one goes to local TV other to projector upstairs (10m decent scart no probs).
For audio you could break it out from the scart lead (messy tho), run a 10m 2 RCA lead, or run a 10m optical from the optical output of the Marantz amp downstairs giving DD upstairs too :) (worth checking that the Marantz will actually do this first!)
M
Mark P
sorry to hijack this thread but i have a question that someone may beable to answer.
Currently i have a scart going from my sky box into a john sims convertor, then a svideo lead out the john sims box into my pte100.
When i upgrade to a sky+ box in the near future, will this set up using the john sims box still give me a better picture than taking my s video lead staright out of sky+ box and into my projector?
thanks, mark
