Panasonic AE1000 judder
Discussion in 'Projectors, Screens & Video Processors' started by ST2007, Sep 21, 2007.
  1. ST2007
    ST2007
    Hi :),
    A few days ago when setting up the AE1000 connected to a Mediaserver with a nVidia 8800 video card (DVI-HDMI connection), I noticed that when playing SD DVD's I got motion judder.
    I looked at the settings of the card and it was set to 1080p60. When changing to 576p, the judder disappeard but the PQ was not so good. I then tried to change the card to 1080p24 but the Panasonic always showed 1080p60 and the image was still juddering (is that a word?).
    Can anyone help?
    Thanks,
    ST
  2. TechieSarah
    TechieSarah
    Jan 6, 2007
    1,787
    Midlands
    +218
    I got the panny and can confirm that my BDP-S300 standalone player set to 1080p/24 shows as 1080p/24 on the ptae1000 menu screen.
    If it helps ;)
  3. stripe
    stripe
    Apr 7, 2004
    1,293
    Scotland
    +123
    Is possible that the 576P refresh rate should be 50Hz, my 900 judders when running at 720P/60 but runs ok at 720p/50 unless it a region 1 disk.
  4. dun_buyin
    dun_buyin
    Feb 28, 2007
    191
    28
    +31
    I think Stripe is right. 576p will be 50Hz. Only HD material will be 24fps and show as 1080p24 on the pj. 480p is 60hz I think so if you are passing a 1080 60hz from 576 50hz material I guess there is either some overhead on the conversion on the media server causing the judder or it is a 3:2 type pull down issue (I think that is what they call it). Someone more knowledgeable may be able to explain better or correct me.
  5. ST2007
    ST2007
    Thanks for your inputs. 576p is indeed 50Hz (and it can be confirmed through the onscreen menu of the AE1000). I was trying to get an universal setup for either SD or HD content.
    When I first put a DVD disc I noticed the juddering and tried to set up the mediaserver accordingly but to no avail. A 1080p50 configuration would be ideal (I think) to setup the nVidia card but I can't get that option to work.:(
    ST
  6. KelvinS1965
    KelvinS1965
    Jan 3, 2006
    17,077
    +8,025
    I've had mine working at 1080p 50Hz, but that was an older CCC driver and I'm literally just fitting a new 2600Pro graphics card which requires a later driver. I'll let you know if I can get it to work again, but I can definatley say that the AE1000 showed 1080/50 in the menu when it was working, if that helps.
    Funny thing is that I got juddering with BBC HD @ 50Hz but not at 60Hz, be interesting to see what happens with the new card and drivers......
  7. ST2007
    ST2007
    That's good to know, thanks. That means all I have to do is to sort out the nVidia's output so that is set to 1080p50 (which I have been unable to do). I went to the refresh options on the settings menu of the mediacenter and set it up to 50Hz, but it still shows 1080p60 on the AE1000 menu... :confused:
    ST
