Panasonic AE100 Fault and Temp replacement Help!!
Discussion in 'Projectors, Screens & Video Processors' started by realitybites, Nov 6, 2003.
  1. realitybites
    realitybites
    Jun 3, 2003
    588
    My Panny 100 has gone bang suspected power supply fault. Am waiting for it to be sorted. Panasonic people have not gotten back to me yet. Can anyone tell me if I am entitled to a substitute while mine is in for repair, rugby world cup on at the moment. Bought it from Robert Whyte recon unit but comes with year warranty.
    Any help greatly appreciated.
  2. pj
    pj
    Mar 15, 2002
    2,404
    87
    w.mids
    +478
    did u contact panasonic directly? seems to be the best option they offer u a loan unit but tell u it could take longer to get one, i called them and i think it took about a week to get it all done (i didnt take a loan unit though)
    will be calling them again soon as i have a horrible yellow stain developing from the top of the screen! anyone else had "this" problem?(already had the psu done!)
  3. realitybites
    realitybites
    Jun 3, 2003
    588
    Thanks for quick reply pj. Yes, just contacted them and getting a loaner would be no prob but they won't have one back for a couple of weeks. Seems power supply has gone so no choice but to go without till it is fixed :rolleyes:
  4. theritz
    theritz
    Aug 17, 2002
    2,451
    Ireland
    +27
    Sounds like heat damage....................... if it's still in warranty period, definitely send it back to Panny.
    Sean G.
  5. realitybites
    realitybites
    Jun 3, 2003
    588
    Thanks Sean, but I think these pearls of wisdom were destined for another post ;)
  6. theritz
    theritz
    Aug 17, 2002
    2,451
    Ireland
    +27
    realitybites,
    Didn't intend to confuse...................my post was aimed at query in pj's post.........
    Cheerio,
    Sean G.
  7. realitybites
    realitybites
    Jun 3, 2003
    588
    Yes, I can see what you mean. Still, excess temperature must have contributed somewhere along the line, so cheers.
