Panasonic A350
Discussion in 'Blu-ray & DVD Players & Recorders' started by Mr.D, Dec 18, 2000.
  1. Mr.D
    Mr.D
    Jul 14, 2000
    11,197
    +1,241
    No it doesn't handle DTS.
    However....and this is a long shot and a bit techie.
    If you stick the firmware for the A310 into it ( the american model) it will according to details I read years ago. Unfortuantely the new firmware also disabled the RGB output ( the 310 not having one).
    But seeing as there were/are no mods that give you DTS no-one seemingly bothered making this available. Your best bet is to get another player for DTS. Unfortunate as the A350 is still a very capable player.
  2. johna
    johna
    Dec 15, 2000
    880
    Kent
    +9
    Thanks for this - I didn't think it did.
    Like you said this is a very good player so I'll hold of the upgrade till DTS becomes standard on Region 2 discs.
  3. johna
    johna
    Dec 15, 2000
    880
    Kent
    +9
    Does anyone now if this player can handle dts??
    I've hooked it up via dig coax to a sony strb940 and played gladiator dts but it doesn't work.
    Any help greatly appreciated.
    John
