panasonic 700 flashes light then dak
Discussion in 'Projectors, Screens & Video Processors' started by Tyjay, Apr 8, 2005.
  1. Tyjay
    Tyjay
    Apr 16, 2004
    7,484
    Bedlington
    +2,945
    first off many appologies if this has been covered before but iv searched and found nowt.
    Anyway i love this projector since around 500hrs ish iv started to notice that the picture will go from normal to dim then back to normal again
    basically the picture is flashing, strange thing is it dosent do everytime i watch it but most times it does.
    This is from sky to component to rgb it happens on all inputs inc hdmi, iv done the flicker tweak on it everytime its used which dosent have any affect with this problem is the bulb dying or is it more serious than that.
    I run it on low power and has never been set any higher as it dont seem to make a great deal of diffrence to my eye's
    any help info would be greatly appreciated
    ty
  2. fallwood
    fallwood
    Sep 10, 2004
    864
    Leeds
    +6
    Sounds like the dreaded brightness flicker to me , is it still under warranty, if so get it back to panasoinic for repair. Do a search for brightness flicker there are quite a few threads on here about it.
  3. Adrenochrome
    Adrenochrome
    Dec 20, 2002
    9,043
    Babel Sensurround
    +207
    It sounds suspiciously like your bulb is about to expire :(
    Adrenochrome.
