panasonic 6
Discussion in 'Panasonic TVs Forum' started by jrne10706, Aug 24, 2003.
  1. jrne10706
    jrne10706
    after reading various posts am i right in thinking:-
    to connect a x-box/ps2/sky d/video to a pwd6 the best way would be scarts to quintro scart box to rgb to vga converter to plasma or:-
    x-box/ps2/sky d/video to quintro scart box to rgb to component converter to component on plasma
    any suggestions? for best picture quality?
    cheers
  2. NeilMcRae
    NeilMcRae
    Sep 2, 2002
    1,191
    41
    London
    +6
    sky/video through scart, xbox/consoles through component.
  3. MarkE19
    MarkE19
    Aug 10, 2002
    17,312
    Rainham Essex
    +2,425
    Your VCR does not output RGB, therefore this can only be connected to composite.
    So......
    Sky to RGB>VGA to VGA plasma input
    PS2 & XBox (via AV amp to switch?) to Component plasma input
    VCR direct to composite input on plasma.
    Mark.
  4. jrne10706
    jrne10706
    my sony db940 amp does not have component out, does this mean i need to buy both converters?
    (i am using xbox as dvd)
    does the pwd6 have composite input??
  5. NeilMcRae
    NeilMcRae
    Sep 2, 2002
    1,191
    41
    London
    +6
    SCART socket takes CVBS and SVHS. So the video will work.
    Neil.
  6. NeilMcRae
    NeilMcRae
    Sep 2, 2002
    1,191
    41
    London
    +6
    The SCART socket has composite input but I wouldn't bother hooking up your AMP to the plasma.
    You don't need to buy any convertors.
    Buy one SCART socket for the plasma hook your video and Sky box through that.
    Xbox -> VGA port [in component mode] You need a component to HD cable.
    GC into extra component port or buy a switcher like this:
    http://www.scancom.ltd.uk/products/avtoolbox/avt-5842.htm and hook your consoles through this and just use the VGA port in component mode. That way if you buy a PS-2 you can hook it up cheap.
    Regards,
    Neil.
