Panasonic 55E
Discussion in 'Blu-ray & DVD Players & Recorders' started by oldrocker, Sep 25, 2004.
  1. oldrocker
    oldrocker
    Sep 25, 2004
    7
    4
    Wolverhampton
    Hi, :hiya:
    just joined, this is my first post and it's a problem!
    Hope I'm in the right forum.
    On chasing playback the machine records what I'm watching so, say I start watching half an hour into an hour long programme, after half an hour I'm back to the beginning again! It doesn't seem to carry on to the end of the programme Have I explained that properly?
    Dave
    Oldrocker.
  2. Rasczak
    Rasczak
    Apr 3, 2002
    21,700
    Warwick
    +2,578
    Welcome to the forums!
    If I'm reading your 'problem' correctly you saying that when you Timeslip you goto the start of the recording and not the point where you timeslipped? Is that correct? If so the solution is to use the Fast Forward button to the point where you were! It's annoying it doesn't just resume - but that's a 'feature' of the recorder I'm afraid!
  3. oldrocker
    oldrocker
    Sep 25, 2004
    7
    4
    Wolverhampton
    What happens is that when I start watching a programme that is still being recorded, let's say 30 minutes after the recording has started, when I have been watching for 30 minutes I don't get to carry on to the end of the recording. It's as though the recorder has switched from recording the programme to recording what's on the screen so I get the programme from when I started watching.
    Sorry, it's very difficult to explain..
  4. pjtownsend
    pjtownsend
    Jan 16, 2002
    3
    Oxford
    Could that be an AV1/AV2 mix-up? I also have an E55 and when initially setting it up found I had not got everything as it should have been and as a result I was getting picture-in-picture recording when I thought I was simply watching what I was recording using time-slip.
  5. Benrudd1
    Benrudd1
    Jan 19, 2003
    961
    Pembroke Dock
    +66
    First thing, I assume you are using DVD-Ram disks?
    Second, when you start recording a programme you are watching you should just press record, then when you want to watch (say 10 mins later) just press play, not stop first.
    You can check if chasing playback is working properly on the players front display. When recording you should get a red line that runs from left to right. When using chasing playback that red line should be followed by a white (ish) one.
    Final thing, I assume there is enough space left on the disk you are using?
    Hope this is of some help :)
