spenna
My setup consists of Panasonic 55 jz-1500 oled TV which I recently bought,a Denon AVR-X4500H and the Xbox series x.When the TV was first setup I signed into my Netflix account,prime video ETC.Then initially I had a problem with enhanced audio return to the Denon AVR.If I watched Netflix ETC on apps in the TV or anything plugged into HDMI inputs on TV(these would be a Google TV Chromecast and the xbox) I had audio drop outs.The amp was being flagged Dolby Atmos so I know EARC was working in that respect that it was sending ATMOS to the Denon amp.Alongside the audio drop out, the front panel display was flickering as if the signal was getting disrupted.I previously used standard audio return on my previous Panasonic TV because that TV did not support EARC and had none of these problems.So I went into menus on the Denon AVR and the TV to make sure all the audio return were active ETC and they were.So then I established the HDMI lead from the EARC compatible HDMI socket on the TV to the Denon must be the problem.The lead is not excessively long only 1.5m so not as if it's 5m plus or anything.I tried another HDMI lead the same problem,then another then it was OK no drop outs.I thought I had solved the problem but I still have the problem with Xbox series X.This is plugged direct into the TV because my Denon does not support 120 Hz,ALLM etc like the more modern Denon avr's.So I am relying on the EARC on the TV.I have tried different HDMI leads in the Xbox itself and gone into the menus on the Xbox and altered different settings,told the Xbox not to send Atmos etc did not make a difference.The latest thing I have established which is the thing that's puzzling me if I tell the Xbox not to do 120hz just do 60hz and keep all other modes active eg. HDR and even Dolby Vision on games and keeping the Xbox plugged direct in HDMI 1 on TV that supports high frame rate etc I have no audio drop outs and the signal is stable,no flickering on the front of the Denon and the AVR is still being flagged as Dolby Atmos.But as soon as I put Xbox into 120hz mode I have audio drop outs.I am just puzzled because I am putting the Xbox direct in to the TV not trying to go into the Denon.I am certain there are no faults on the Denon or the Panasonic TV because they work alright in every other respect.Has anyone else experienced this,and if so have they found a way to resolve it?.Has a last resort I did not really intend this is buy a newer AVR that allows 120hz ETC and plug the Xbox direct into the AVR.Thanks.
